Is it the master cylinder?
Old Aug 3, 2013 | 11:01 PM
dudesqueak's Avatar
Default Is it the master cylinder?
Symptoms:
Soft clutch, missed shifts at high RPMs (embarrassing), rough shifting. The one different symptom I'm seeing is that the friction point is when the pedal is further out (less than 1'' from all the way out). Most people say that theirs is when the pedal is barely away from the floor.
Ideas? Also thinking about going with the tick. Anything compare for cheaper?
Old Aug 4, 2013 | 05:59 PM
dudesqueak's Avatar
so NO ONE has any ideas?
Old Aug 4, 2013 | 06:21 PM
1BAD02WS6's Avatar
Why not try the man. Trans section?
But yes it sounds like upgrading your master will help, but what's clutch set up?
Old Aug 4, 2013 | 06:22 PM
Sladester2's Avatar
tick. and no.. no other master cylinders as good.
Old Aug 4, 2013 | 08:18 PM
dudesqueak's Avatar
Stock clutch and it doesn't slip.
