broken smog pipe question
Old Aug 7, 2013 | 05:45 PM
gotgrowth's Avatar
Default broken smog pipe question
i believe it is a smog or egr pipe
is comming ff the bottom of my passengers side header, its an aluminum pipe that is attached to a fitting like this... http://www.hawksthirdgenparts.com/pr...15388_zoom.jpg
it snapped off pretty close to the header..
what is this pipes purpose, can i drive like this safely , is there an easy fix other then replacing the header or having the pipe welded back on?
Old Aug 7, 2013 | 06:13 PM
sreve's Avatar
That is a cover used after the air pump is removed.
Either of those things will work or weld a patch on the pipe.
Old Aug 7, 2013 | 06:32 PM
Wicked 94TA's Avatar
My EGR pipe broke off right where it was welded to the header. I just broke it all the way off, found a short bolt the same diameter of the hole, shoved it in there and welded it in place. Looks a little cleaner now, you can't see it all from the top side of the motor.
Old Aug 7, 2013 | 07:04 PM
gotgrowth's Avatar
Can I just jb weld over the hole?
Old Aug 7, 2013 | 07:19 PM
I looked into that but it won't hold up to the heat.
Old Aug 7, 2013 | 07:57 PM
gotgrowth's Avatar
im trying to avoid taking the header off in order to do this... any idea how muhc a shop would charge?
would it be ok to drive it like it is for a ;ittle bit?
Old Aug 7, 2013 | 08:40 PM
It wasn't too bad to get to underneath the car but then again I don't have A/C anymore so there is a lot more room on that side now. I drove mine for a day or so and it was annoying and sounded like **** but I wouldn't wait too long to get it fixed.
