GZ vacuum pumps
Old Aug 25, 2013 | 12:45 PM
M.BOZZ's Avatar
Default GZ vacuum pumps
I found just 2 posts on this. Has anyone else used the gz vac pumps ? Post up the good and the bads on this, thank you
Old Aug 25, 2013 | 09:24 PM
high n dry's Avatar
their better than moroso ones. a bit pricey, but they work well!
Old Aug 25, 2013 | 09:58 PM
assassinz28's Avatar
I installed mine because of random oil leak issues and it fixed the problem. I also added a manual tensioner and the set up looks nice.
Old Aug 27, 2013 | 10:33 AM
nhra686's Avatar
They are actually less expensive than the other brands when you add up everything that comes in the kit. A GZ sportsman kit is $839. It will cost well over $1000 to get everything that comes in the GZ kit from the other manufacturers. Not to mention ease of installation...
Old Feb 28, 2014 | 10:44 PM
z28josh's Avatar
just finished installing mine. I went and got a shorter belt and was able to get it all fit without bending any ac lines. only had to remove accumulator bracket
