2001 Trans Am Oil Temp Sensor Issue
I had installed a sensor there years ago for an autometer gauge and it started leaking recently now that I've been driving the car again. I pulled it off tonight and found that the sensor goes down too far into that part and stops turning because it's hitting the other side, so I highly doubt the threads will seal.
Is it possible to get the part from a vette that's already drilled out and threaded? Then In could try to get an adapter to make it work with an autometer sensor. I'd rather do that since I don't have anyone to thread the stock part for me anymore. Other option being get the stock part and drill it out and find a way to have it threaded for the 1/8 NPT.
Problem is, I don't know what this part is called, so I'm having a hard time tracking down a replacement.
Any input is appreciated. Also interested if there are any aftermarket options.
Thanks
I ordered that, the Autometer oil temp sending unit (part# 2253) and a 1/8th NPT to 12x1.5 adapter (part# 2277). Got all the parts but this combo won't work because the diameter of the sending unit is too big to fit into the adapter. Anybody have any suggestions on how to make this work with the 12x1.5 threads the part already has?
Thanks again.
Thanks again
