Rusty harmonic balancer?
Old Sep 2, 2013 | 01:47 PM
silver86's Avatar
Default Rusty harmonic balancer?
I'm putting my gto back together after a head/cam install and my balancer is pretty rusty. Is this common and should I replace it or somehow clean it or just reinstall it? Id like to keep it cheap so either installing it or somehow cleaning it would be ideal. Any opinions?
Thanks!
Old Sep 2, 2013 | 01:58 PM
jsteele90's Avatar
mines rusty also, if it bothers you just hit it with some high heat engine paint and itll be good
Old Sep 2, 2013 | 05:40 PM
sleepinghawk's Avatar
When I was installing my idler and tension pulleys couple weeks ago I took a electric wire brush and a dremel with the wire brush attachment and just cleaned it up. I also had to install new belts so while under the hawk I just cleaned it up. Then I sprayed this rust neutralizer that Lowe's sold over it.
Old Oct 19, 2013 | 07:38 PM
TipsyMcStagger's Avatar
Originally Posted by silver86
I'm putting my gto back together after a head/cam install and my balancer is pretty rusty. Is this common...
The balancer on my LS2 (out of a GTO) is rusty. Ugly, but functional, I suppose.
Tipsy
Old Oct 20, 2013 | 12:34 PM
demonspeed's Avatar
It's not mine! woo hoo!
I think all the Gen III/IV balancers get that rusty look. Go for an underdrive pulley if you care to replace it, otherwise don't worry about it.
Old Oct 20, 2013 | 04:31 PM
Blackpanther99's Avatar
Youll be fine. Mind posting a pic of it?
Old Oct 20, 2013 | 04:33 PM
silver86's Avatar
I just went ahead and ordered/installed a PB 25% UDP
Old Oct 20, 2013 | 07:39 PM
Here's mine:
