maf directly to filter
I'm doing an lq4 swap into a '68 c10 and I'm about finished. Looking into air filters right now. I've seen that the 99-up Silverado kits will work for me but they actually put the filter right behind the battery tray where there is little air movement. Is there a specific coupler that I need to clamp a cone style filter directly to the maf or can I just use a standard silicone one. I realize the maf end is slightly smaller than 4" but I don't see why it wouldn't work.
The only thing I've found that might be close is spectre part number 9900033. Sorry for not having a direct link but my phone doesn't paste in these sorts of text boxes.
I'm looking at spectre pn 8162 for a cone if anyone else is curious.
I could be wrong though.
If you do this setup do not even think about removing the screen from the MAF. You might invest in a Saxon maf screen to further help get clear MAF readings. My idle seems more solid since I installed mine. For like $15 it can't hurt
http://www.saxonpc.com/100mm-cells-for-100.html
That filter is also going to be considerably small for your application. I high recommend you try one of the ebay CAI kits for a 99+ 5.3 engine. I bet you can use the whole cold air kit on your truck and it comes with a HUGE filter with the stack in it. It is $60 shipped so lots of bang for the buck.
BTW it is the exact same thing as the Spectre kit sold at part stores for $150. So if it doesn't fit you can probably sell local and get your money back.
The price of a proper sized filter for your application from any other source is likely $35-40 alone.
http://www.airaid.com/u-build-it_intake_systems.aspx
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
As far as the filter goes, this means that it probably would have worked ok with the smaller filter, but I would suggest to anyone reading this that you get a good size one anyway. The ebay one looks pretty decent aside from it being absolutely ENORMOUS! Seriously, I've already gotten several comments from people I don't even know asking whether I'm compensating haha.
The pic doesn't do it justice. Look at the pcm and battery in front of the filter for perspective.
Do you have another MAF you could try? Even if the table is wrong it should run, just might be rich or lean.
Is the engine stock? Does it idle poorly both cold and warmed up?
