How To Remove The Intake
Old May 2, 2004 | 11:45 PM
two02camaro's Avatar
Exclamation How To Remove The Intake
Does anyone know of a website that shows you how to remove your LS6 intake off of your car and how to put it back on? I have been trying to find somehting on the internet and I cant find it anyplace, does anyone know of a website that shows pictures and full instructions on how to remove the Intake on the LS1 motor????
Old May 2, 2004 | 11:53 PM
SilverGhost's Avatar
Motorboater
www.ls1howto.com might have some stuff in the cam/heads install stuff. lemme see if i can help real quick.
take off MAF, Throttle body, etc
use fuel tool and take off fuel line to rail
unplug all injectors on both sides
unplug white connector on each side for the injectors
pop vacuum lines out of holders and shove aside
disconnect MAP sensor and vacuum line that goes to the heater
pull vacuum line out of brake booster..easier than trying to disconnect that line from back of intake
undo the bolts that hold the intake to the heads..you will not be able to remove the back 4 ones..they will hit the windshield cowl..leave them in loose
lift the intake off..you'll have to hold those back bolts up in the air to clear their holds in the heads..have a buddy help you with this if needed.
that should be a good basic steps for you.
