oil sending unit question?? help please
Old Sep 15, 2013 | 07:37 AM
s10_ls1's Avatar
Default oil sending unit question?? help please
i was goin it switch to a mechanical oil gause and didnt know if i took the sending unit out and put my gauge there if it would turn the check engine light on or mess with computer..thanks in advance
Old Sep 15, 2013 | 10:17 AM
samdogmx's Avatar
I am pretty sure the sending unit behind the intake does not even go to the PCM its only for the warning light in the dash, so it shouldn't give you any problems if you remove it.
Old Sep 15, 2013 | 07:23 PM
s10_ls1's Avatar
Good deal thanks alot.
Old Sep 16, 2013 | 01:33 AM
joecar's Avatar
Y-car: oil pressure sensor goes to PCM.
F-car: oil pressure sensor goes to IPC.
If your PCM is from a Corvette, then the PCM will throw a DTC (P0522, P0523).
Old Sep 16, 2013 | 12:58 PM
s10_ls1's Avatar
The pcm is out of a camaro so should be good then
