Higher than "normal" oil pressures.
According the the factory manual these are the minimums... Mine seems a bit on the high side. I'm using 20/50 rotella.
Anyone else seeing pressures similar to this?
Oil Pressure Minimums (hot):
6 psig at 1000 engine rpm.
18 psig at 2000 engine rpm.
24 psig at 4000 engine rpm
On the low side, the lowest I've seen was after a track day, where I saw 270* oil temps. It was down to 20 psi at idle.
