Oil pressure problem please read
Old Oct 14, 2013 | 06:17 PM
cjconnor713's Avatar
Default Oil pressure problem please read
i have a 2001 camaro ss. Fully warmed up. When i am out of gear and i rev the car, oil pressure rises as it should up to around 55 psi. When accelerating easy the oil pressure rises fine. I did notice that when i push the clutch in to shift it does increase slightly and once back in gear drops (2-3psi) and begins to rise. In traffic i noticed when accelerating quickly the oil pressure drops quite quickly 10+ PSI. My question is why under quick acceleration would it drop quickly, but when free revving why does it rise normally? I run Royal Purple 5-30 and AC delco filter. any advice or direction would help greatly
Old Oct 15, 2013 | 07:20 AM
maf_diver's Avatar
Double-check your oil level, sounds like it's sloshing away from the pickup under acceleration. Would be worth checking with a mechical gauge too. The sensors go bad sometimes.
Old Oct 15, 2013 | 07:46 AM
01ssreda4's Avatar
Yep, confirm with a mechanical gauge and consider checking crankshaft end-play and thrust bearing wear can cause oil psi trickery.
Old Oct 15, 2013 | 08:05 AM
rgr thank you very much, after work today i will check oil level.. i was thinking today how it had been a little more than 2 months since my oil change.
