Underdrive pulley
Old Oct 25, 2013 | 08:59 PM
sbf's Avatar
sbf
Default Underdrive pulley
I pulled my stock 98 corvette balancer off today and it was light compared to a summit racing underdrive pulley.is all brand underdrive pulleys way heavier than the stock balancer or is there a lighter brand
Old Oct 25, 2013 | 09:24 PM
ULTIMATEORANGESS's Avatar
SLP claims to be lighter than stock.
http://www.lmperformance.com/6628
Old Oct 25, 2013 | 09:43 PM
99Bluz28's Avatar
Powerbond makes the SLP pulley. The Powerbond is the same pulley for less.
http://rpmspeed.com/product_info.php...ts_id=23444948
Old Oct 25, 2013 | 10:20 PM
01ssreda4's Avatar
I've seen threads of Summit's pulley coming apart. I wouldn't buy one.
Old Oct 25, 2013 | 10:53 PM
badazz81z28's Avatar
The SLP pulley is a Power-Bond pulley (exactly, down to the part #). It says Power-Bond right on the pulley.
My SLP Pulley was cheaper than the branded power-bond and it came with a bolt. It all depends on where you buy it.
free shippng
http://www.summitracing.com/parts/sl...t/model/camaro
Old Oct 25, 2013 | 11:41 PM
AmarilloWS6's Avatar
I have a Powerbond 25% underdrive on my C5 and the Powerbond was heavier than the stock pulley for sure. Don't have a pic on a scale to prove it though.
Old Oct 26, 2013 | 12:49 AM
Decadence75's Avatar
The powerbond is slightly heavier than stock. You can also get it as a kit from SDPC for $219 which includes an arp style permanent bolt and new belts.
I weighed both when I did my cam swap. Stock was 10.6 LBS
Powerbond was 11.4 LBS
Old Oct 26, 2013 | 06:37 AM
sbf's Avatar
sbf
Does the f body power bond pulley weigh 11lbs also
Old Oct 26, 2013 | 05:19 PM
sbf's Avatar
sbf
Any body
Old Oct 26, 2013 | 05:32 PM
99Bluz28's Avatar
The F-body crank pulley should weigh a little bit more.
Old Oct 26, 2013 | 05:36 PM
Those pictured are f-body pullies.
Old Oct 26, 2013 | 06:11 PM
99Bluz28's Avatar
The crank pulley for the vette does sit closer to the engine block(shorter) than the F-body pulley does.
http://www.ls1howto.com/content/info...asppullies.jpg
Old Oct 26, 2013 | 07:49 PM
sbf's Avatar
sbf
Will it be a problem to run the f body pulley on a vette motor.its going in my foxbody and I want have ps,ill have a manual rack.ill have alternator and a/c
Old Oct 26, 2013 | 08:32 PM
As long as you are running f-body drive accessories and there isn't a spacing issue in the fox body then it should be fine. If you go with a y-body pulley, you will need to use y-body front accessories since the pulley alignment will be slightly different.
Old Oct 27, 2013 | 07:40 AM
sbf's Avatar
sbf
Ok thanks
Old Oct 28, 2013 | 04:31 PM
1BAD98LS1's Avatar
The little bit of extra mass isn't always a bad thing, esp. @ higher rpm's
Old Oct 29, 2013 | 11:46 AM
BigCityFire's Avatar
I get my SLP underdrive pulley either today or tomorrow.
Does it provide a noticeable difference when driving on the street? I've been reading some reviews around the internet that make me think I may have wasted some money when I could have just bought the super damper.
Oh, and BTW - my car is all stock except what is in my signature.
Old Oct 29, 2013 | 04:47 PM
1BAD98LS1's Avatar
If your not going to be doing internal mods I'd say the SLP is all you will need. You start needing a super damper when you start installing camshafts and have a need to turn over 6500 rpm's etc. Your not going to "feel" any difference on the street but it shows on the time slip at the track..
Old Oct 29, 2013 | 10:07 PM
DANOZ28's Avatar
i hope your wrong, i have one on my car installed last summer. any links or photos of these damaged pulleys? thx ps bigcity on the web i've seen people claim anywhere from 5 - 12 rwhp gain for the ud pulley. 3 months after install im currently having a voltage gauge issue, not sure if old battery or alternator so im replacing both.
