33lb or 36lb injectors for LM7
Old Oct 31, 2013 | 09:21 PM
sakers288's Avatar
Default 33lb or 36lb injectors for LM7
Ok so i'm gonna get a stage 3 port job on the heads, a 269Lr HR12 comp cam, maybe a different intake, and some wiseco flat top pistons in this 5.3. Does anyone think 36lbs would be overkill?
Old Nov 1, 2013 | 10:32 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
I'd go with 36lb injectors and just tune for them. That way you'll have a little more room to grow for the future.
Lonnie
Old Nov 1, 2013 | 02:20 PM
arock24's Avatar
Really no such thing as "overkill" with injectors bc you can tune them down as you please. The bigger injector will just allow for more room for growth down the road, if needed.
Old Nov 1, 2013 | 02:34 PM
Sales2@Texas-speed's Avatar
Only within reason is that true. If your injector is way to big for your application the injector won't be working hard enough to work correctly. It can cause a problem with spray pattern etc.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 2, 2013 | 12:48 AM
sakers288's Avatar
Alright i'm gonna go with the 36's. Thanks guys.
