Rst clutch on stock flywheel?
Old Nov 15, 2013 | 08:24 AM
sweet99ss's Avatar
Default Rst clutch on stock flywheel?
Anybody running rst clutch on stock flywheel with good results? It shows to be able to run on stock flywheel, but i've seen some people question it.
Old Nov 15, 2013 | 09:15 AM
97camaro383's Avatar
Maybe the manual transmission section would be a good spot for this post! Zachary you should know better!
Old Nov 15, 2013 | 09:27 AM
alexus6798's Avatar
I asked the same question when I bought mine and the verdict was yes, it can be ran on stock flywheel, but not recommended if you plan on beating on it because of the heat that will be transferred through the stock flywheel.
Old Nov 15, 2013 | 10:46 AM
sweet99ss's Avatar
Well I talked to 2 performance shops now and talked to McLeod themselves and everyone says to run the stock flywheel and it will be good to go. So probably just going to get it resurfaced and call it good
By Brett Foote | 2026-06-04 05:00:17
