Engine number location Ls-1
Old Nov 17, 2013 | 06:06 PM
Thumpt's Avatar
Default Engine number location Ls-1
Hi guys im hoping someone can tell me where I can find the engine number location.
The engine is an ls-1 from a 2002 Camaro, the car is not in my possession at the moment it is with a shop doing some work on my truck. I need the engine number for registration purposes here in Australia.
Thanks for any help.
Mark.
Old Nov 18, 2013 | 09:06 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Welcome to LS1tech! SEARCH will be your best friend around here.
Old Nov 25, 2013 | 05:01 PM
Thumpt's Avatar
Thanks Paul, found it as per your photo.
Again much appreciated, Mark.
Old Nov 25, 2013 | 07:18 PM
2002 blue z28's Avatar
Unrelated question, but can I use that spot to verify if I have an ls6 block?
Old Nov 25, 2013 | 07:25 PM
Z28 6spd's Avatar
Casting # will tell you if it's an LS6. It's up a bit from the engine number, just below the driver side head.
Old Nov 27, 2013 | 11:16 AM
88gtman's Avatar
Just look at the top left front of the engine and see if there is a little bullseye/ring cast into the block. If so, it is an LS1 block.
Old Nov 28, 2013 | 01:38 PM
01ssreda4's Avatar
This, is the quicker way.
