Breslin Split-Lock header bolts
Old May 7, 2004 | 08:44 AM
bryan c's Avatar
Default Breslin Split-Lock header bolts
http://www.jegs.com/cgi-bin/ncommerc...24&prmenbr=361
Anyone used these?
Old May 7, 2004 | 09:24 AM
Dope's Avatar
Those look really nice. For the money (a little more actually) I'm going to go with ARP header studs though. Once you've done one header install you realize how awesome studs are.
Dope
Old May 7, 2004 | 11:52 AM
bryan c's Avatar
Thanks a lot, now you've complicated my decision.
Old May 7, 2004 | 12:55 PM
soundengineer's Avatar
really..the studs make the most sense....You wont strip out the bolt holes with studs....
Old May 7, 2004 | 02:08 PM
P Mack's Avatar
Is it a lot harder to put the headers in with header studs? Or do you just thread the studs in after the headers are in place? Also, who sells header studs? Thanks.
Old May 7, 2004 | 02:53 PM
have to pull them off far enough to get to the flat spot to get them tight...but you can get at that with a wrench no problem...dont know if its any easier to put them on first or put the headers up there first...should be about the same... and studs dont have to be overbearingly tight...so you wont have to worry about stripping out the threads on the heads..
