Is this belt routing ok?
Old Nov 20, 2013 | 07:59 PM
ryanleiker's Avatar
Default Is this belt routing ok?
The engine is a 2002 Lq4 6.0L with truck brackets on the Alt/PS Pump and a custom bracket for an R4 compressor on the top left with a rod end tensioner instead of a spring tensioner.
My main concern is whether or not it's "legal" to route the belt around the water pump before the crank pulley or if it "has" to come after. Seems like it won't be a problem.
Old Nov 20, 2013 | 08:20 PM
S10xGN's Avatar
OK if your engine is rotating backwards...
Old Nov 20, 2013 | 08:21 PM
ryanleiker's Avatar
oh, ya, I forgot to mention that. It is...
Old Nov 24, 2013 | 12:43 AM
bczee's Avatar
would also check the Waterpump direction..
