over axle exhaust pipe
the slp setup that i have has a 3" pipe, the output of the y pipe is 3" and the slp cme muffler has a 3" input. the muffler output i think is 2.5". and last time i looked i could not find a replacement muffler having 3" in and two 2.5" outlets. so depending what i get and i'm looking for something quiet, are there different size over the axle pipes available?
also, i have had and can get the whole rear portion of the exhaust out from under the car. it's all stainless pipe and no rust, and i tried once to separate the pipes but had no luck. what are the odds of being able to separate those and not wreck them after 10 years? can an exhaust shop do that, or should i just not waste my time and cut it and use new pipe?
As for the over-axle pipe, I know I've seen rockauto with some, but I'm not sure if they are stainless. Stainless works might be able to help if you call and say you just need an over-axle pipe. Who knows though.
Muffler choices I'm not sure off the top of my head I'd have to search, and most sites are blocked with the computer I'm on...
-J
All of these have a 3" inlet, and dual 2.5" outlets in a stock muffler configuration.
Hooker Aero Chamber 21729HKR
Magnaflow #12267
Dynomax Ultra-Flo #17227
Not loud enough for you? Get an electric cut out.
Too loud? Never heard anyone say that before, but perhaps a bullet in the I-pipe?
I've said it before, and ill say it again, there is no way I would chop up a factory cme.
