what AFR head and cam
Old Nov 21, 2013 | 05:11 PM
Sickpalms's Avatar
Default what AFR head and cam
i want to get a set of heads and cam from afr in the near future
ls1 gto m6
but im just curious as to which cc is the most well rounded
and what cam would match
prefer bigger intake and exhaust
500 at the wheels?
Current mods
90/90 fast
lt headers
2.5 true dual x2 mangnaflow mufflers
possibly tuned
unaware of a aftermarket cam WOT is loud sounds cammed to me(california car so could have an emissions cam)
but the buschur evo x i raced said i didnt have one
we rolled from 20 to 120 and i started to pull him at the top half of 5th and he let off. idk if this helps explain the power im putting down as of now i walked my buddys 350z(just exhaust) and mustang 4.6gt(inake exhaust)
Old Nov 24, 2013 | 10:06 PM
Mazzenger's Avatar
If you are going with AFR heads then I would contact Tony Mamo on this board. He will tell you what you need to know.
Old Nov 25, 2013 | 08:48 AM
trans_am7935's Avatar
BAM, problems solved!
You should always pick your cam first, and match your heads to suit your cam, not the other way around.
Old Nov 25, 2013 | 09:55 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Originally Posted by trans_am7935
BAM, problems solved! You should always pick your cam first, and match your heads to suit your cam, not the other way around.
WHAT?!?!
No. You pick the HEADS first. The cam is based off the heads, not the other way around.
Old Nov 26, 2013 | 06:08 AM
ULTIMATEORANGESS's Avatar
Smile
i have old AFR 205s with a custom cam through my tuner. i make excellent power through an auto and 4.10s on a mustang dyno.
Old Dec 9, 2013 | 07:57 AM
Sickpalms's Avatar
lmao
thanks guys ill give him a holler!
