FAST 90/90 or 92mm?
BTW, you can also use the FAST TB adapter with the FAST 102 intake manifold.
http://www.coloradospeed.com/fast-ls...e-p-15376.html
http://shop.brutespeed.com/FAST-1460...146029-KIT.htm
http://www.summitracing.com/parts/fst-146029-kit
Grab the 90/90 and be done. Over 500hp NA has been made through them no problem. No changing fuel rails, and no changing injectors (until you need to)
Sell what you have now, like the intake, TB, extra TB's, and reap the rewards of a good cheap deal.
I would either try to get a lower price on the 90/90 (then you can try it as is and sell the TB if it is junk) or else just get the 92 and a good TB and be done with it.
There will be 0 hp difference. The 92 was a revision to correct some issues such as the MAP sensor fitting loose and a couple other small things. The size of the TB has very little to do with power gains, it is runner shape and plenum volume that make the fast superior, not the opening size (hence why a 102mm intake with a 90mm tb is still an improvement, new runner design)
