Name this alternator bracket
Old Dec 25, 2013 | 12:07 AM
WillRyan's Avatar
Default Name this alternator bracket
What alternator bracket is this, with the tensioner?
I will only be running a alternator off the crank. Factory LQ4 alt. it's perfect for what I need!
Electric radiator mounted water pump, manual steering and no AC or heat.
Old Jan 8, 2014 | 12:54 AM
WillRyan's Avatar
Bump!
Old Jan 8, 2014 | 09:58 AM
Burken01's Avatar
Originally Posted by WillRyan
Bump!
I'm not sure which that is, but look into the modular turbo bracket.
It mounts the alternator in the same position, instead of using that tensioner it comes with an adjustable bar support for the alternator and that's how you tension the serpentine belt.
Old Jan 8, 2014 | 01:48 PM
WillRyan's Avatar
Thank you! That one looks to mount on the factory water pump! I wont be running the factory pump. I'll look into some that might actually mount to the head!
Old Jan 8, 2014 | 08:55 PM
boosted tundra's Avatar
The one you posted first doesnt seem like it would tension properly with the tensioner there right below the alternator.
I am making a billet alternator bracket that mounts to the head basically. I am running 05+ corvette balancer and water pump on an lq4 with truck alternator only. It is going to mount to the driver side and incorporate a idler to improve belt wrap unlike the dirty dingo one.
So you are not running a dummy pulley on water pump?
Old Jan 9, 2014 | 12:28 AM
WillRyan's Avatar
No, my water pump is mounted to the radiator.
Basically will look like this!
The only thing on the block will be the hoses running to the AN fitting water pump adapter brackets.
Old Jan 13, 2014 | 04:47 PM
Would this work on the driver side for you?
Old Jan 17, 2014 | 02:05 PM
ROBBIEZ91's Avatar
how much for that bracket?? can you pm me a price boosted tundra??
 Michael S. Palmer
Old Jan 17, 2014 | 02:11 PM
ss4chad's Avatar
Carlos Magentia DeLousche!
Hey, you said name the bracket. That's what I'm calling it.
Chad
Old Jan 17, 2014 | 06:56 PM
WillRyan's Avatar
Yes something like that would work!
Old Jan 17, 2014 | 07:06 PM
sepsis's Avatar
I shall name it, Herald.
