At what point is a vacuum pump necessary?
Old Jan 5, 2014 | 08:20 PM
big dave's Avatar
Default At what point is a vacuum pump necessary?
My newly built 408 has been burning a decent amount of oil...plus, it smokes quite a bit going down the track. It doesn't have a catch can, but the pcv is still intact. I'm sure the motor is ingesting a lot of oil without the catch can. Is a vacuum pump necessary? How would I know if I need to install one?
Old Jan 6, 2014 | 04:59 PM
studderin's Avatar
its not a ring seal "fixer". you should fix the problem 1st.
any engine it will work on and add power.
