kinda disappointed in headers.....
TSP acknowledged my complaint and forwarded it to pacesetter who said "We'll work on the fitment in future versions" lol. great. Not like i'd want to take them off.
Just gotta get manly with it and it will be fine. Everyone has had the same troubles. I also did the poly trans mount which helped, and if your motor mounts are shot you might consider doing one of them (REAL PITA) but i didn't need them in the end. just the $20 poly trans mount which isn't that bad in the vibe dept.
I've never had issues with speed bumps, the hookers my bro has the clamps scrape going sideways over the speed bumps so its give and take.
overall for the money saved i dont think they are that bad, but they are definitely not the best design. They are cost effective and probably make just as much power as any other +$100 headers out there.
would i buy them again? nope. But who wants to swap out headers and redo the Y pipe now that its been done. too much work. As i said once its been dealt with it won't bother you.
If you are really impatient, take a valve spring and wedge it between the drivers side on the ORY you'll get rid of 80% of the rattling till you can have it fixed.
ghetto, yeah, but it was better than the aweful noise and the KR.
Have the y-pipe bent down, it's the only way. If after that it still comes through the pedal, that's hittin the k-member and needs to be notched, i need to do that still, UGHJeff- we need to get a skinny dremmel attachment and fix mine
Oh yes, almost forgot, when I got my car dyno'd, they hit the k-member, caused 2* of KR and I lost about 10hp in the top end.
-Steve
-Steve
-Steve
If not, most muffler shops should be able to figure out where to heat and bend... good luck!
has your friend done that before, to your car?
Yes, they worked on my Y-pipe, and have been doing most of my exhaust work on other cars for over 15 years.
You may need to do a poly trans mount, stock ones are weak and tend to crack and move alot anyway.
I'll send you the pm info tomorrow.
