consequences for running wrong maf
Old Jan 8, 2014 | 07:11 PM
goob8869's Avatar
Default consequences for running wrong maf
I have a 67 Camaro with ls6 in it but the wiring harness I have will not plug into the stock maf sensor and gives a different part # for what I need. What could result from running a different maf sensor
Old Jan 9, 2014 | 07:40 AM
spy2520's Avatar
Nothing if it gets tuned with the maf. And depending on if it's 5 pin or 3 pin, you may need to either remove or add a separate IAT sensor. 5 pins have IAT built into maf. Of course if that is your only problem several companies make adapters for this.
