Engine missing block plate(plate between engine and transmission)ok to do?
Old Jan 19, 2014 | 07:26 AM
bishopz28's Avatar
Default Engine missing block plate(plate between engine and transmission)ok to do?
In the process of putting motor back in car I have misplaced the block plate.will it hurt anything to run without it?its a 99 trans am with a 4l80 and lq4.the distance from converter to flywheel is ok.the starter looks like it will be fine but won't know until it is cranked over.thanks in advance for any help.
Old Jan 19, 2014 | 10:31 AM
.boB's Avatar
I bought a used LS1 from a 2001 Trans Am. Complete from trans tail shaft to water pump. When I took it apart, I was surprised to find that there was no block plate. There was only a small plastic piece near the starter.
