Is this an LS1 or LS6 intake?
Old Jan 23, 2014 | 04:40 PM
Freefallin's Avatar
Heard if its got an EGR hole after the throttle body then its LS1. Well i see two hoses going in the intake from either side of the throttle body. The white stick in the pic is pointing to them.
Attached Thumbnails Is this an LS1 or LS6 intake?-forumrunner_20140124_011804.png   Is this an LS1 or LS6 intake?-forumrunner_20140124_012951.png   Is this an LS1 or LS6 intake?-forumrunner_20140124_013014.png   Is this an LS1 or LS6 intake?-forumrunner_20140124_013046.png   Is this an LS1 or LS6 intake?-forumrunner_20140124_013125.png
Is this an LS1 or LS6 intake?-forumrunner_20140124_013157.png   Is this an LS1 or LS6 intake?-forumrunner_20140124_013244.png
Old Jan 23, 2014 | 04:58 PM
jrpimp00's Avatar
need the part number. doesn't have egr but could be a vette ls1 intake
Old Jan 23, 2014 | 05:28 PM
Freefallin's Avatar
Where is the part number? Thought it was at the bottom.
Old Jan 23, 2014 | 05:58 PM
Burken01's Avatar
It on the driver side or passenger side of the intake right by the middle injectors
What year car?
Old Jan 23, 2014 | 06:02 PM
Freefallin's Avatar
Its 12561184
HioSSilver's Avatar
It's a ls6. Ls1 intakes had a egr port. Ls6's did not.
Old Jan 23, 2014 | 06:08 PM
99Bluz28's Avatar
It's on the drivers side between the two middle injectors.
http://www.dumontduneriders.com/invi...1336839732.jpg
FYI, the LS1 dips down in the middle on the bottom, the LS6 is flat.
Burken01's Avatar
Its 12561184
That's a ls6 #
 Michael S. Palmer
Old Jan 23, 2014 | 06:14 PM
Majestic9C1's Avatar
what pile of sand did you find that engine under?
Old Jan 23, 2014 | 06:45 PM
poltergeist 02's Avatar
Some LS1 intakes didn't have the egr, and look very similar to an LS6. The best way to find out is get the part number or look at the bottom of the intake. The bottom of an LS6 intake is flat, the LS1 has a hump.
To the OP, that number is an LS6 intake part number like said above.
Old Jan 23, 2014 | 08:53 PM
HioSSilver's Avatar
Ok..... Would they have come on the vette or gto? All the fcar ls1 intakes had egr.
Old Jan 24, 2014 | 02:27 AM
Burken01's Avatar
97-2000 vette- ls1 intake w/no egr
98-00 fbody- ls1 intake w/egr
01-04 vette- ls6 Intake
01-02 fbody- ls6 intake
04 gto- ls6 intake
05 gto- ls2 intake
Old Jan 24, 2014 | 06:54 AM
HioSSilver's Avatar
Thanks....Shoulda known it was the vette. Never seen one with egr and since the ls1 intake went out of production after 00 then the gto never got that.
Old Jan 24, 2014 | 08:43 AM
Freefallin's Avatar
haha! I knew someone was gonna comment on that.
That's living in the desert. No matter how well you clean the engine bay, two weeks later you open the hood and that's what you see. Frustrating really.
Old Jan 24, 2014 | 10:17 AM
Burken01's Avatar
You need to fill a hot bathtub up with a lot of dish soap and give it an Encino man bath!!
Old Jan 24, 2014 | 06:14 PM
1BAD98LS1's Avatar
That thing needs a pressure washer!... but make sure the intake bolts are tight first...
