QTP ORY & Corsa Cat Back
Old May 11, 2004 | 08:20 AM
Z28GSXRTim's Avatar
Default QTP ORY & Corsa Cat Back
OK, after dealing with my old leaky y-pipe, I decide to get a QTP ORY. I have the entire exhuast system off the car and will be doing everything myself (I've learned that if you want something done right, you have to do it yourself ). Does anybody know if the QTP y-pipe will bolt directly to the intermediate pipe in the Corsa cat back system? The Intermeidate pipe being the one that goes from the y-pipe to the over-the-axle pipe. I cannot tell from the picture on QTP's site if it has a reducer or anything to make this a true bolt up.
TIA
Old May 11, 2004 | 08:41 AM
NOBR8KSS's Avatar
The Corsa intermediate pipe will probably need to be modified to accept the QTP 3" y-pipe exit. It shouldn't be any big deal for an exhaust shop though.
Since aftermarket cat-backs are designed to hook up to the stock y-pipe, which has a 2 3/4" exit...someone correct me if I'm wrong. I've never run this setup before...I run duals
Old May 11, 2004 | 03:44 PM
Ed FvC's Avatar
Don't waste your money on their Y. If you want to do it right, get a Flowmaster merge collector and have the rest fabbed up yourself. It'll sound absolutely awesome once you put it on with your Corsa. I've recieved countless compliments on the same setup.
Old May 11, 2004 | 03:47 PM
travisnd's Avatar
my QTP cat ypipe and SLP exhuast. my slp exhaust had to be cut off some to accommodate the ypipe.
Old May 11, 2004 | 03:55 PM
DERTY's Avatar
The Bull
Back when I had mine I had to fabricate a transition from 3" to the intermediate pipe. The intermediate pipe is designed for the factory y-pipe. It was easy enough to do.
