regular 80lb injectors vs e85 injectors
Old Jan 31, 2014 | 01:58 PM
98WhiteLsX's Avatar
Default regular 80lb injectors vs e85 injectors
There's no difference right? I'll be buying 80lbers and ill be running e85.. Will 80 lbers on e85 with a 400lph pump be able to get to 650rwhp? Maybe run a boost a pump or hotwire kit?
Old Jan 31, 2014 | 02:07 PM
cmac06's Avatar
Not in most cases. Injector dynamics makes some newer injectors that use stainless internals to hold up better, but they are a lot bigger than 80 lbs.
Old Jan 31, 2014 | 08:24 PM
98WhiteLsX's Avatar
What you mean not in most cases?
Old Feb 1, 2014 | 07:33 AM
cmac06's Avatar
Get the Bosch or Siemens injectors, you'll be fine. The 80s will be more than enough to get you to your goal.
Old Feb 1, 2014 | 07:37 AM
Gray86hatch's Avatar
I have Siemens 80lb engine makes 750 crank injectors are at 79% on E85
Tim
