Motor build Help! need opinions
Ive come down to two choices on cam. 228R like I had in my last car or possibly going a little smaller and going with a 224. I also plan on a 100 shot down the road.
My car is Daily driven. I commute with it, my only complaint with my 228 was the gassy smell at idle so im trying to avoid that.
My main question though is with my heads. I recently was given a set of 241's which I intend to have hand ported and then milled as well.
I know that 243's are better but im not trying to break records here and its nice that I can drive my car still and get the 241's worked on prior to install.
So how much can I mill? I know I wont be going larger than around a 230 duration cam for a fact.
So lets take the 228 for this example. how much could I mill the head to bump compression? what head gasket should I use? at what point would I have problems with the intake sealing up? how much compression can I safely get? Currently I just run 91 (best available in my area) and I have 29 degrees of timing with no knock.. What would you guys do?
