A/C recharge
Old Mar 6, 2014 | 03:53 PM
countryguy1717's Avatar
Default A/C recharge
The A/C doesnt blow cold in the camaro I bought, Was thinking about using one of those Interdynamics MAC-134 EZ Chill Refrigerant Refill with Charging Hose and Gauge - 18 oz. kits.
Any way to test to see if its just got a refrigerant leak or if my ac compressor is bad?
Also anyone know exactly where to add the refrigerant?
Old Mar 6, 2014 | 04:09 PM
MadFirehawk86's Avatar
The low pressure port is on the dryer in front of the battery....that is where you fill. As far as the leak you can purchase some uv dye to put into the system and use a black light to find the leak. The dye is usually next to the refrigerant at the parts store. After you find and repair the leak purchase the cans with only pure r134a refrigerant in them....no stop leak or so called performance enhancing chemicals combined with it.
Certified ac tech
