Clearance to floor pan?
Old Mar 21, 2014 | 02:09 PM
reinhardt02's Avatar
Default Clearance to floor pan?
How much clearance do I need between the exhaust and the floor board? I installed long tube headers and a 3" y pipe, and it is a bit low. I am thinking I can tweak it for a tighter fit, but not sure how tight is too tight. Thanks guys.
Old Mar 22, 2014 | 12:23 AM
Siciliano15's Avatar
usually about a pinky fingers width is good. if you have poly motor mounts you could probably get even closer.
Old Mar 22, 2014 | 03:03 AM
99Bluz28's Avatar
With poly motor mounts you should be fine with 1/8".
Old Mar 22, 2014 | 07:24 PM
1/8"?! I have about an 1/8' now! I have poly mounts btw. Looks like I'll be fighting w/ the exhaust some more soon.
Old Mar 22, 2014 | 10:22 PM
ez2cdave's Avatar
What about heat transfer to the floorpan with the exhaust pipes that close ?
Old Mar 23, 2014 | 07:08 AM
_JB_'s Avatar
I have both poly engine and transmission mounts, and the engine still torques. I'd say 1/2" should be ok. Only way to really know is to drive the car and adjust as needed.
Old Mar 23, 2014 | 01:03 PM
99Bluz28's Avatar
There's only two places my exhaust is that close, and that's on the drivers side Y-pipe where there's floor/chassis bracing. So there's still a good gap between the actual floor and the exhaust pipe, and the floor doesn't get any warmer than it did with the stock exhaust. Furthermore the only reason I can get my exhaust that close is because of the Ball/Socket joints on my BBK header & Y-pipe.
