What head bolts? 5.3...
Old Mar 30, 2014 | 09:16 PM
Mavn's Avatar
"I MAID THEESE"
Default What head bolts? 5.3...
And I have an unknown year 5.3 short block. I've tried every set of head bolts at oreilleys and none fit. I'm just trying to mock it up with my 241 heads and nothing fits! Any help is appreciated!
Old Mar 30, 2014 | 09:27 PM
autogeek23's Avatar
Get your casting number. That will help figure out what year it is
Old Mar 30, 2014 | 09:33 PM
Mavn's Avatar
"I MAID THEESE"
Where would that be? ^ first time digging into a motor.
Old Apr 12, 2014 | 11:49 AM
autogeek23's Avatar
good question. i think its on the back of the motor
Old Apr 12, 2014 | 02:48 PM
cmac06's Avatar
The head bolts are hard to find; doubt you'd find them at most stores. They are all 11mmx2.0 the length varies, but the threads are the same. The ten closest to the valley are the only ones that are standard metric 8mmx1.25.
Old Apr 12, 2014 | 06:02 PM
1FastBrick's Avatar
There is a 4 or 5 digit alpha numeric code on the front right of the block. It might also be in the lifter valley area
This will tell you what year the block was produced.
Old Apr 12, 2014 | 08:59 PM
cmac06's Avatar
Run a caliper down the outside 11mm bolt holes, and one of the center, if they are the same depth, it is later model short bolt block, otherwise it is an early Gen III with the unequal length 11mm bolts.
