Coolant leak, I need help
IF that is the one, that is only to put warm coolant fluid thru your throttle body during starts, I guess to warm it up and thaw it out during cold months.
If you broke that plastic fitting on your radiator (the top one near fill cap), If you broke it completely down to the radiator, you may be able to thread in a barbed fitting with a threaded end that will hold, clamp the hose on it. If you only broke off a piece of it, check and see if a new hose can still be clamped on it. and run the other end of the hose past the throttle body to the metal T fitting I talked about earlier. I believe you can also plug the inlet and outlets for that tube, but need an expert opinion. Worse case, buy a new radiator, they aren't expensive. A performance one costs $125 I believe, but make sure you buy the year specific for your car
I did break the outlet completely off. Theres nothing for the hose to attach to.
If it was my car and I didn't have much money to replace that radiator, I'd take to a radiator shop and ask them if they can fix it (they may be able to thread in a fitting, and attach that hose to it). If they quote you an insane amount of money (remember a new radiator isn't very much $50-$150), you can do it yourself with just the price of the fitting (probe about $15), however you will need to shop for that fitting size, I use JEGS.com, Ebay, etc.. You may need to add a backing nut since the radiator wall may be too thin to hold a threaded fitting, I'd cut a slice of high temp tubing and use as a rubber washer on both sides so you don't crack through the radiator. You only want it snug. I repair med equip and I'm pretty sure I could make it work. Good luck, these things happen and it is a good opportunity to learn something about your car. If you put in a new radiator, you will learn alot. Check out youtube for instructional vids. You will need to drain and then add coolant. Only use what is recommended!
