QTP cut out wiring?
Ok i tried to draw a little diagram,you should get the idea no problem,I'f you have a problem toss me a PM.And the black dot in the upper middle is the same on the back of the switch to tell you what way the switch is for the pins.Good luck! And this works fine for me.I also used one of the other nx switches for the SLP fan which works fine also.
