intake/tb 102 worth it LS6 NA?
Old May 3, 2014 | 04:41 PM
grocerygetter's Avatar
Default intake/tb 102 worth it LS6 NA?
vs doing a 90mm dbw tb ported out to work with a Fast 92mm...is the 102 fast and a NW 102 tb worth it? not much price difference here. Going toward a nice custom cam and TrickFlow 215s.
and if the verdict is just do the Fast 92mm...can I use a new ls3 dbw tb or does it have to be the ls2 dbw tb to work with ls6 plug adapter?
Old May 3, 2014 | 04:52 PM
Rise of the Phoenix's Avatar
Since you plan on doing heads and cam, the 102 would be a good investment. You will need upgraded fuel rails with the 102.
Old May 3, 2014 | 04:59 PM
yeah I saw...I was going to do the LS2 rail set up and a bit bigger injector more than likely.
Old May 3, 2014 | 05:06 PM
That would work too. I think the FAST 92 setup works quite well on stock cube LS1's.
Old May 3, 2014 | 05:20 PM
HCI2000SS's Avatar
The 102 will give you maybe another 5 hp over the 92
Old May 3, 2014 | 05:56 PM
ULTIMATEORANGESS's Avatar
Smile
imo its worth it especially when adding H/C.
Old May 3, 2014 | 06:25 PM
BrntWS6's Avatar
The 102 is better through the whole curve....the graphs I've seen are usually about 10rwhp and 5rwhp peak. A 92/102 work well and is easier to tune. You're not looking at that much more money since the 92 is $100 more out of the box.
Old May 3, 2014 | 07:07 PM
Blackpanther99's Avatar
With cam and trick flow heads upgrade coming soon yup the 102mm is worth it.
Old May 3, 2014 | 08:04 PM
Hardcoresoldier's Avatar
It helps, but is 10hp really worth $1500?
Old May 3, 2014 | 09:32 PM
I'm doing it. Ok so tb...needs to be the nw102? Looks like only one out. Well tpis is out but more money.
Old May 3, 2014 | 09:35 PM
you can run what ever size TB you want on it. FAST sells adapter plates for all the sizes.
Old May 3, 2014 | 09:56 PM
I'm after what is optimum though.
Old May 4, 2014 | 08:17 AM
Mike Morris's Avatar
Ported 102 is best. You have to decide if you want to spend the money for it
Old May 4, 2014 | 08:52 AM
WS6ICK2k's Avatar
This but I would add a few more ponies in the equation.
Old May 4, 2014 | 09:10 AM
agreed
Old May 4, 2014 | 01:07 PM
BrntWS6's Avatar
Yeah I would expect a 20-30 rwhp gain. But don't forget a new MAF, bellows and lid....I got a 90mm GM maf on ebay for $40 shipped. I think a lot of people don't do everything in front of the TB and that's why they don't see the gains others do. I personally gained 20rwhp from 4k rpms all the way to redline.
I think Maryland speed is having a sale on them now.
Old May 5, 2014 | 04:12 PM
yup..coming from a ls3...I forgot about the earlier maf's. thanks!
