Normal to have sludge so quickly
Old May 3, 2014 | 05:37 PM
*98Formula*'s Avatar
Default Normal to have sludge so quickly
I recently drained radiator and put in Dex-Cool with non distilled water about 3 months ago into my car. Ever since it has developed this think reddish sludge in the radiator. Is this normal temp's and everything are fine never any issues there. I have been thinking of draining it again and trying to flush things out a bit. I won't be able to get the block plugs out and crap for a full flush so would it be okay to just drain radiator fill car up with just water then let it run drain again and repeat a few time's? It's making me nervous with the sludge for sure and I ran with just water for quite a while with no problems. Never really gets cold enough in the south to worry about freezing to much.
Old May 3, 2014 | 05:45 PM
ULTIMATEORANGESS's Avatar
yes,dex cool tends to sludge a little but i havent heard of any problems as long as its properly maintained.
Old May 3, 2014 | 05:56 PM
It turned my entire radiator red and my cap has like a bubble of sludge on it everytime I take it off. That seems a bit much to me. Hoping I don't have a bad head gasket but it sounds like it's just the dex-cool crap.
Old May 3, 2014 | 06:26 PM
Italianjoe1's Avatar
What did you have in there before? Dex-cool doesn't play nice with most other coolant formulas.
Old May 3, 2014 | 06:54 PM
it also supposedly doesnt like a perfectly sealed system.
but besides that shitty looking red buildup ive had no problems.
Old May 3, 2014 | 09:35 PM
I ran just straight water for over a 2 years without any issues at all. I put coolant in it this year cause temps have been weird down here and didn't wanna risk any block cracking issues. I've also noticed that my radiator will never be full. I fill it up drive it then it goes down about 8-10 cups. It never gets lower than that it just seems strange to never be full since i haven't had any problems I just kinda let it go.
Old May 3, 2014 | 09:56 PM
patSS/00's Avatar
You have to use distilled water, anything that contaminates it will cause sludge. Also, if you have the stock PS cooler, lookup threads about leaking.
