Vic jr install
Old Jun 14, 2014 | 01:24 AM
SPOOLIN Z28's Avatar
Default Vic jr install
I picked up a Vic jr intake a little while back. I know I need fuel rails but what else will I need to complete this install minus throttle body. Fuel lines, fittings, fuel pressure regulator? Any help is appreciated.
Old Jun 14, 2014 | 02:05 AM
97WS6SCharged's Avatar
What kind of car are you installing it on?
Are you planning to run an elbow or a 4bbl style throttle body?
Old Jun 14, 2014 | 11:36 AM
It will be in my 98' camaro and will be using a 4150 throttle body.
Old Jun 14, 2014 | 09:40 PM
You won't need a regulator. You can build the fuel line and cross over using:
1x Russell 644123 -6 to 3/8 Quick Disconnect
3x Russell 610165 -6 90 Hose ends
1x Russell 610025 -6 Straight Hose end
3x Russell 660463 -6 to 3/8" npt
1x Russell 662053 3/8 npt hex key plug
1x Russell 632075 -6 black nylon hose 10 ft
This will put the inlet at the front of the driver side rail and the cross over at the back of the intake. You also may want to get some rubber line to route the canister purge line back under the car since you probably won't be able to retain it. I didn't reuse mine.
You'll need some way to cut the cowl along with an air filter or carb hat and an adapter for the brake hose (3/8 pipe threads to 3/8 or 1/2 hose, not sure which). The intake should have come with throttle brackets but you may need a different throttle cable for the 4150 TB, I haven't used one on any of my stuff yet.
