MAP Sensor from LM7 to LS1 Intake
Old Jun 17, 2014 | 01:34 PM
Jack Bradham's Avatar
Default MAP Sensor from LM7 to LS1 Intake
I have put a ls1 intake on my LM7 and am moving as many of the sensors over as I can. The MAP sensor did not seem to fit and it had 5V written on it.
The first thing I did to make it fit was to grind off to little nubs that kept it from fitting on the LS1 intake.
It fit pretty well after.
My question is, since I am running a 1999 LS1 Computer (reprogrammed) is this sensor compatible with that computer?
I am not sure if the 5v is incompatible because I know some early stuff was 12v. Or if that 5v marker actually means it is a 5v sensor.
thanks
Old Jun 18, 2014 | 05:42 PM
Anybody got any insight?
