Missing my obd II connection please help!
Old Jun 21, 2014 | 05:21 AM
Steve T's Avatar
Default Missing my obd II connection please help!
I'm starting to do my harness as it is getting close to starting my swap.
In my plethora of ignorance I realized that I didn't get my obdII connection with the harness so I'm a little stuck before I even get started. Which wires get connected to which wires when I'm fitting my new obdII connector? Also, can I use ANY chevy obd connector or does it have to be vehicle specific?
Guys, I'm really really stuck and dead in the water here. Please help!
Old Jun 21, 2014 | 07:41 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Please tell us what vehicle the harness was made for. In other words, what does the harness think it is?
Old Jun 21, 2014 | 02:25 PM
Steve T's Avatar
2001 lq4 from a 1500 2 wd
Old Jun 21, 2014 | 05:21 PM
Paul Bell's Avatar
I would suggest you have a look at these and I'm sure you'll find what you're looking for:
http://www.bing.com/search?q=obdii+p...82c1992d42309d
Old Jun 22, 2014 | 12:41 PM
LilJayV10's Avatar
Is this what you are looking for?
Old Jun 22, 2014 | 02:51 PM
Mike_hawk's Avatar
The wire for your odb2 should be number 58 on the blue connector to your PCM, it should be a dark green wire. Then all you need is 12v and a ground. You can use any odb2 plug, I got mine off of ebay, make sure you get the "male" end, the one I got came with had pigtails that I had to switch around. Use this to wire it up. http://www.mstewart.net/miata/wiring/OBD-II_Pinout.jpg
Old Jun 22, 2014 | 06:03 PM
Steve T's Avatar
Thanks a million guys I was getting scared. Electrical is not my strong suit
