Griffin radiator hose.
Old Jun 21, 2014 | 03:26 PM
necrocannibal's Avatar
Default Griffin radiator hose.
I'm running the typical Griffin radiator most FI guys use, I bought the car done this way. Anyway my lower hose started leaking so I figured I'd fix it. Well it turns out the port on the radiator and the port on the thermostat housing ate two different sizes. My let hose is metal that someone rigged to fit so now my metal hose is cracked and I can't use a stock hose. I know lots of people use the same radiator so what hose did you use?
