Cylinder Head question
most of the mods listed in the invoices from Speed INC. I was able to verify but some of the mods are internal and I can't see them for obvious reasons unless I tear it down. Now on one of the invoices it lists ARE stage 1 cylinder heads. Now I know ARE has a mixed bag when it comes to reputation. But what I am trying to find is how to I.D them to see if they are still on the car or were removed. What were these heads were they some stock heads that were port and polished or a custom build? Any info on these will help. I am trying to find out what I have as a starting point.
Also forgot to add when the heads were installed per invoice it also shows SLP long tube headers, BMR sub-frame connectors were installed and those I know are still on the car. It also lists push-rods and comp cams ovate springs being installed.
Thanks for any help, Shuckman00
First of all look on the outside of the head for casting number. Easiest way to tell if they are still ported is to unbolt the headers and swing them out of the way. Then look at the exhaust port and see if it's cast or ported.
but I guess not lol.Thanks for your help
Thanks for the help
