qtech question (electrical)
Old May 19, 2004 | 10:09 PM
98hc4mula's Avatar
Default qtech question (electrical)
QTECH wiring question
I did search
but could not find out some things
1-can someone give me some insight as to where to connect the cables----its an automatic with no TCS
2- also can you let me know where is the easiest wire that is on by ignition to connect the positive wire
3-any pictures could help
Iam in the process of finishing up the qtech and also I just finished making my own clear corners.
the formy should be upgraded with this little things by tommorow.
Old May 20, 2004 | 12:09 AM
Mike K.'s Avatar
I grouned mine to the chassis using an existing screw by the shifter, I mounted the switch in the ashtray for the ignition wire I cant remember were I hooked it in at but you can always use the ignition on the back of the radio or just run it to the fuse box. doesnt qtp say where to hook it in in the instructions?
