Harmonic balancer for Fbody
Old Jul 13, 2014 | 11:00 AM
99WS6_'s Avatar
Default Harmonic balancer for Fbody
Hello guys,
I have an issue with my new built engine. Turns out when I took my original Balancer out it did not have a key way. This built engine the forged crank does have a key way. Do you guys know of any balancer made for the fobdy accessories and has a key way.
Has anybody else run into this issue?
Thanks,
Old Jul 13, 2014 | 11:22 AM
poltergeist 02's Avatar
ATI makes them.
Old Jul 13, 2014 | 09:45 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Fluidampr will broach a damper for you.
Old Jul 16, 2014 | 10:34 AM
5.0 LsX's Avatar
couple clamps and a drill press and you can cut your own, or take the keyways out and just run it like stock
Old Jul 16, 2014 | 12:04 PM
Paul Bell's Avatar
I'm curious-how would you do that?
Old Sep 29, 2014 | 07:35 PM
trevmust's Avatar
how come ati uses a sticker instead of laser etching the info onto the surface? and would a 2 keyway damber be ideal on a supercharged engine making 800 or so hp?
Old Sep 30, 2014 | 10:35 PM
soundengineer's Avatar
Originally Posted by trevmust
how come ati uses a sticker instead of laser etching the info onto the surface? and would a 2 keyway damper be ideal on a supercharged engine making 800 or so hp?
dont know where you got that info...
my ATI balancer timing marks are etched...
the front has a sticker...but not the timing marks.
and a double keyway, or a keyway and a secondary pin is always a good choice when you want to make power.
the ATI balancer comes with a single keyway, but you can order it with a 2nd keyway cut into it as well.
Old Oct 5, 2014 | 09:08 AM
Exactly this ^^^^ My ATI damper and it is etched as well.
 Michael S. Palmer
