close up pic of 4150 throttle body with cable???
Old Aug 10, 2014 | 04:24 PM
red_00z28's Avatar
Just finished my super victor/4150 install. I used the ls1 36" Lokar cable and fabbed it to work with the stock traction control/cruise control module. Lokar Cable part #TC-1000LSIU
Old Jun 29, 2015 | 10:55 PM
Mike Blanco's Avatar
I am also doing a similair setup. I am trying like hell to use the original hood on my 65. That is the reason I went with this low profile K&N. Right now the original hood will fit. However, the throttle body arm strikes the bottom on the air filter.
I am wondering if I go with the recommended bracket, and lokar cable, can I just cut the throttle body arm so it will clear the bottom of the air cleaner?
Old Jun 30, 2015 | 01:18 PM
RobsZ28's Avatar
Yes, you can cut the arm. I had to cut a 1/4" off mine so it would clear the air bell I have on my car now.
Old Jun 30, 2015 | 01:56 PM
Good deal, I just ordered my pedal, cable and bracket. Should all be here by Fri.
Old Apr 22, 2016 | 03:55 PM
Major Shart's Avatar
Originally Posted by soundengineer
Start a new thread instead of using somebody elses thread...
as far as a throttle cable....
you can buy the Lokar piece for the throttle cable bracket separately and then go to the dealership and buy a 99 Fbody Cable for a Non ABS Non Cruise control car....if you need a 4150 style carb end, then you can just go to orileys and but the carb end for about $5
cut the throttle cable off to the length you need it to be and put the carb end on it
otherwise, you just buy the Universal Cut to fit cable from Lokar with the end you need for the pedal side of it.
I had the CSR bracket....but its made for a Carb, not an EFI 4150
and it lines up like ****....
so I made my own bracket that lines it up correctly
This picture was from when my Motor was running with a 350 shot of nitrous.
You wouldn't still have the plans you used to make your bracket would ya?
