Help! engine starts and dies
Old Aug 13, 2014 | 10:38 AM
Ls1-kid's Avatar
Angry Help! engine starts and dies
I just installed Pacesetter headers and Y-pipe and the engine starts up roughly (like a cam) and dies unless I give it throttle. could it be loose/broken sparkplugs ? or maybe the O2 sensors ?
Old Aug 13, 2014 | 10:40 AM
Ls1-kid's Avatar
there is also a knocking sound
Old Aug 13, 2014 | 10:58 AM
babbage1109's Avatar
Double check all your spark plugs and wires? Make sure your o2 sensors are plugged in?
Old Aug 13, 2014 | 01:14 PM
Paul Bell's Avatar
That's MISTER MODERATOR
You broke, disconnected or reconnected something incorrectly. Go over everything.
Old Aug 13, 2014 | 02:47 PM
Nissan LS240's Avatar
does it run fine until it warms up then die? you might of crossed the o2 sensor connectors, which will cause it to add fuel to wrong bank and remove fuel from the other bank,
Old Aug 13, 2014 | 10:13 PM
Ls1-kid's Avatar
Thanks for the help guys ! It was the egr hose that leads into the intake. It was missing an O-ring.
