LS1 GTO TB problems
Second, now my cable won't reach the lower mount hole on my TB. Now it only reaches in between the two holes. So I tried the higher mount and the TB only opens 48%(HPTuners), if I use the lower mount I can open the TB 100% but then it stays open 5-10%. Also my goat revs to 3-4k when using the lower mount, I'm assuming I have to back out some crank timing to fix the high revving ignition. I added crank timing because my goat was having trouble turning off after the install.
I had a heck of a time with the steering rack during my cam/head swap so I'm wondering if I bent something accidentally, if there's something that could've been bent? I banged the driver's side headers around pretty good trying to clearance the steering rack during removal and install.
My Fast 92/NW 92 were already installed before the cam/head swap with zero issues previously.
Thanks in advance. All mods in my sig.
Also, 10 year old car. Things wear out. Might have been worn/fragile already and bumping around finished it off.
So how do I pull the cable if that's what needs to be done?
