oil on heads???
Old Oct 7, 2014 | 04:28 PM
lbm13186's Avatar
Default oil on heads???
So I have been having some issues w/ my knock sensor so I pulled the intake off today and i had some oil on the head around the intake seals. Should i be worried about this, if so how can i prevent it?? or what should i do?
Maybe a catch can would help??
any help will help
thanks guys
Attached Thumbnails oil on heads???-img_1636.jpg   oil on heads???-img_1637.jpg
Old Oct 7, 2014 | 05:20 PM
lbm13186's Avatar
anyone??
Old Oct 7, 2014 | 06:44 PM
redtan's Avatar
catch can
Old Oct 7, 2014 | 06:45 PM
99Bluz28's Avatar
Yes, a quality CC will definitely help.
Old Oct 7, 2014 | 08:10 PM
mikh338's Avatar
I have the same issue, but a lot more oil. Was told its pcv issues, and to ditch the ls1 valley cover snd run the ls6. I have the updated pcv valve and a catch can as well.
Old Oct 7, 2014 | 09:38 PM
99Bluz28's Avatar
Mighty Mouse(MM), RX Performance, Elite engineering, all make high quality CC's.
http://www.coloradospeed.com/advance...d=catch%20cans
http://www.ws6project.com/user_stor/...oducts_id=6352
Old Oct 9, 2014 | 12:17 PM
lbm13186's Avatar
thanks guys for all the help ill prob switch to a ls6 valley cover and do a catch can soon to prevent this from happening in the future
Old Oct 9, 2014 | 03:09 PM
99Bluz28's Avatar
My experience with the LS6 valley cover is that a good CC is way more effective. I'd go with one of the high quality CC's I listed above first.
 Michael S. Palmer
Old Oct 9, 2014 | 03:39 PM
thompson's Avatar
Run a catch can and vent to atmosphere. Keep that hot air and oil out of your intake and you will be much happier with the life of your car.
Old Oct 9, 2014 | 03:44 PM
lbm13186's Avatar
alright thanks for the good info guys really appreciate it, i figured that the CC would do the trick but wanted to ask around and see what ppl thought before going out and spending the money
Old Oct 9, 2014 | 03:47 PM
lbm13186's Avatar
one last thing i know there are a few ways that ppl are running the tubes to the cans and wondering if anyone has found a way that works the best or if there is a way to stay way from for any reason??
thanks again
Old Oct 9, 2014 | 05:10 PM
99Bluz28's Avatar
I'd run the driver side valve cover rear port to the CC inlet, CC outlet to the intake manifold passenger side vacuum port inlet. Cap the passenger side valve cover rear port, and run the front passenger side fresh air inlet port to the throttle body fresh air outlet port. If the CC you get doesn't have a PCV valve put one before the intake manifold side vacuum port inlet.
Old Oct 9, 2014 | 05:45 PM
99Bluz28's Avatar
Not a good idea on a street driven engine unless you do very frequent oil changes, otherwise a lot corrosive combustion blow-by ends up in the oil and eventually damages the engine.
For a street driven can you only want it venting to atmosphere if there's positive crank pressure, with a one way valve right before the breathe filter.
This way you can maintain a traditional pcv system, and with used along with a CC keep a majority of the oil vapor out of the intake manifold while also keeping blow-by contaminated in the oil to a minimum for a long engine life with normal 2-3k oil filter changes.
Old Oct 9, 2014 | 06:53 PM
lbm13186's Avatar
good to know it is def a street car so thanks for the good information (why i ask bc i dont know everything)
Old Oct 9, 2014 | 08:22 PM
99Bluz28's Avatar
That's the best reason to ask!
