NA 600 crank HP combo ?
Later , If I upgrade from LQ9 , to a 415" LS3 bottom end , would 600 crank hp and 550 torque be attainable ? Using the 220 heads , Performer RPM dual plane, cam in the 230's , and 1-7/8 long tubes ? I could trim down the plenum , or add a spacer , but hood clearance is an issue.
Car is 3435# without me in it , 3600 stall , 350 gears . From some research , the 220 TFS heads will work well on the 364" and the 415" , but I'm always open to more suggestions to achieve my goal. Thank you .
BTW, very nice looking car!
If you're staying with the LQ9 block and bore in the 4.00-4.03 range then cathedrals all the way but something a bit bigger than the as cast 220s unless you plan on getting them worked. For a 415 with 4.065 bore ported LS3s will do the job.
Or I could go half way for now , and step up the 6.0 lq9 with a set of AFR 230 v2 heads . I'm not sure how those would work with my 4.00" bore , cam , intake, and stall. The intake has good air velocity, and the cam is on the small side.
