header flange leak
Old Oct 20, 2014 | 09:53 AM
mikesimpalass's Avatar
Default header flange leak
I have a set of pacesetter long tubes that I can't seem to keep from leaking. IM currently using Percy multi later aluminum gaskets.
Is it ok to use gm mls gaskets , 12617944, and to use 2 gaskets between the header and head to try and fix the leak?
Old Oct 20, 2014 | 11:22 AM
GtoProject's Avatar
In my experience, almost all aftermarket exhaust manifold gaskets are prone to leaking. Go with real gm gaskets and see if that fixes the problem. I wouldn't recommend multistacking gaskests, but feel free to if you want. If any of this doesn't fix the problem you may just have warped flanges. You could always try putting a square across the face of the flange to see if it has flatspots, divets, etc.
