Starts then dies- where to start??
Does that help any?
I havent considered the fuel pump being bad- my first guess would be IAC if it was an unrelated issue since that is how it is behaving.
I will add it to the list of things to check
Uncovered a few more pretty interesting clues. For starters I got locked inside my Camaro for about 5 minutes, and slightly started panicking...just a little. Yes, you read that right I was literally locked in my car.
I was doing some filming of the flashing lights and what is happening and what works and what doesn't in the car (which I will post a little later) but as I was filming I decided that I would test the locks, they didn't work...then suddenly some power jumped back to the car and I hit the lock button- of course the doors locked (both were closed and windows up) then Boom, power goes back off...Ok, I go to unlock it manually with my finger, except I cant... it's like something was powering the lock mechanism to permanent "engage" mode or something...try as I might I couldn't get the bloody thing on either door to slide back open
... Never ever have I ever seen or heard of anything like that happening, and I am baffled actually...I farted with the key, got a juice of power back and the door unlocked... once I unlocked it, I had no issues sliding the locks back and forth by hand...Secondly, I did some more digging, pulled the battery out, pulled hard on the positive battery terminal boot and a corroded mess of wires just crumbled and fell apart. So that is definitely one of, if not the entire issue (my thoughts)
So...what do I do to replace the wires? 1 black and 2 red are coming from the boot- I am assuming with a quick trace, 1 goes to the alternator (black) 1 to the fuse panel and one to the starter.... it was the black wire that goes to the alternator that was toast...so that has me a bit stumped to? because I should then still have power from the fully charged battery going to all the systems no?
In any event, what fittings and gauge wire do I need to replace all of this stuff?
- The first 10 seconds is showing what the car is doing when I pull the key out of the ignition
- 10 -20 seconds is showing how I have no power to any controls
- 30-50 seconds is some weird gauge sweeps that I can't explain
- 1:00-1:19 is when I manage to lock myself in the car- I couldn't pull the lock mechanism manually, it kept snapping back like the solenoid was permanently energized to lock
- 1:19-1:45 is more random flashing of the dash with the key pulled out
- 1:45 to end power is restored, but no start condition.
Had the BCM looked at professionally and they resoldered a few spots and said it looked great.
Got the car back on the road today, drove around a bit, got home...BOOM same thing, no start, gauge sweep, gauge lights faintly flashing when I pull the key from the ignition.
Loss of all power to all items- radio, lights, locks, windows, etc. Turn the key and it is like there is zero power in the car
I am so stumped it isn't funny. Ignition switch maybe?
