LS1 Solid Motor Mount !!HELP!!
Old Oct 23, 2014 | 01:28 PM
SS Rider'z's Avatar
Default LS1 Solid Motor Mount !!HELP!!
Well I was in the process of installing my LS into My camaro today but Notice the holes are not lining up? I also have a crack in my k member I think it may be bent.. Anyone???? I've been fighting but nada. There is a good gap on the driverside pedestal (pics) But passenger side is perfect??
Attached Thumbnails LS1 Solid Motor Mount !!HELP!!-img_20141022_124652-1-.jpg   LS1 Solid Motor Mount !!HELP!!-img_20141023_115546-1-.jpg   LS1 Solid Motor Mount !!HELP!!-img_20141023_115600-1-.jpg   LS1 Solid Motor Mount !!HELP!!-img_20141023_115613-1-.jpg   LS1 Solid Motor Mount !!HELP!!-img_20141023_115634-1-.jpg
LS1 Solid Motor Mount !!HELP!!-img_20141023_115640-1-.jpg   LS1 Solid Motor Mount !!HELP!!-img_20141023_115653-1-.jpg   LS1 Solid Motor Mount !!HELP!!-img_20141023_115711-1-.jpg   LS1 Solid Motor Mount !!HELP!!-img_20141023_115737-1-.jpg   LS1 Solid Motor Mount !!HELP!!-img_20141023_115744-1-.jpg
Old Oct 23, 2014 | 01:46 PM
03Sssnake's Avatar
I have the same UMI mounts, un-bolt them from the motor, bolt the pedestals up and try one side at a time. FWIW I did this by myself, it sucked ***, took 8 hours! If you have a buddy that can help, would recommend you call him over!
EDIT: You can probably leave the passenger side in place, but keep the bolts loose, just un-bolt the drivers side mount from the block, bolt up the pedestal and try to line up the motor.
Old Oct 23, 2014 | 01:50 PM
SS Rider'z's Avatar
Im going try one side but the thing is I have one side completely bolted up just fine then the other side just doesn't want to fit?? Ill try loosening the mount from the block next
Old Oct 23, 2014 | 01:52 PM
03Sssnake's Avatar
You will also want to leave them loose for re-installing the transmission. You will not get the pilot bearing stabbed if they are tightened all the way...You can also loosen the k-member bolts to the body for re-installing the transmission.
Old Oct 23, 2014 | 02:05 PM
SS Rider'z's Avatar
Yes Your right on that I think what ill be doing is dropping the entire k member the fitting my engine & trans together & installing completely
& your right it does suck by yourself (: Ill bug one of my buddies to help me
Old Oct 23, 2014 | 02:31 PM
03Sssnake's Avatar
I just put a tranny back in my fbody, ended up loosening the K-member bolts, not all the way, but very close. I did not have to disconnect brake lines either. If you don't have one, would recommend a low profile tranny jack from harbor freight, especially if you are lone wolfing this job.
This is the one I used...
http://www.harborfreight.com/450-lb-...ack-39178.html
